断电后、控制器无法启动
适用场景
- FAS2750
- DS224C
问题描述
- 断电后、控制器无法启动、磁盘架ID显示88
- 在BMC日志中、PSU状态异常
Sensor Name State Current Critical Warning Warning Critical
Reading Low Low High High
Bat FRU LED OFF
Battery RemCap Desc READY
Battery Charge Failed? FALSE
Battery Charge Bad? FALSE
Battery Capacity Message GOOD
Voltage Spike Frequency normal 0 -- -- -- 3
Voltage Status GOOD
Temp Low Shutdown UP
Temp High Shutdown UP
SNMP Bad Fan Count MULTI_FAILED
Chassis is Under Temp NO
Chassis is Over Temp NO
PSU2 Bad invalid --
PSU1 Bad invalid --
PSU2 invalid --
PSU1 invalid --
PSU2 ON invalid --
PSU1 ON invalid --
PSU1 INFO FRU_AVAIL
PSU1 INFO FRU_AVAIL
PSU1 FRU MULTIFAULT
PSU2 FRU MULTIFAULT
Partner Status A_SIDE_PRESENT
PSU1 Present PRESENT
PSU1 5V not_available -- mV -- -- -- --
PSU1 12V not_available -- mV -- -- -- --
PSU1 5V Curr not_available -- mA -- -- -- --
PSU1 12V Curr not_available -- mA -- -- -- --
PSU1 Fan 1 not_available -- RPM -- -- -- --
PSU1 Fan 2 not_available -- RPM -- -- -- --
PSU1 Inlet Temp init_failed -- C -20 C -- -- -20 C
PSU1 Hotspot Temp init_failed -- C -20 C -- -- -20 C
PSU2 Present PRESENT
- 从维护模式开始
sysconfig -v
、磁盘架0中的所有磁盘不会显示
Mini-SAS HD Vendor: Molex Inc.
Mini-SAS HD Part Number: 112-00435+A0
Mini-SAS HD Type: Passive Copper (unequalized) 0.5m ID:00
Mini-SAS HD Serial Number: 906130996
ID Vendor Model FW Size
01.0 : NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.1 : NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.2 : NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.3 : NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.4 : NETAPP X341_SSKBE900A10 NA02 857.0GB (1758174768 520B/sect)
01.5 : NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.6 : NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.7 : NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.8 : NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.9 : NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.10: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.11: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.12: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.13: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.14: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.15: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.16: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.17: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.18: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.19: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.20: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.21: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.22: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
01.23: NETAPP X341_SSKBE900A10 NA01 857.0GB (1758174768 520B/sect)
Shelf 0: DS224-12 Firmware rev. IOM12E A: 0120 IOM12E B: 0120
Shelf 1: DS224-12 Firmware rev. IOM12 A: 0230 IOM12 B: 0230
