AFF A400/FAS8300机箱温度过高:无法读取多个内部温度传感器
适用场景
- AFF A400
- FAS8300
- FAS8700
- 基板管理处理器(BMC)
问题描述
event log show
报告多个传感器不可读错误。
node1 ALERT nvmem.battery.notPresent: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
node1 ERROR callhome.chassis.ps.degraded: Call home for CHASSIS POWER SUPPLY DEGRADED: PS 1
node1 EMERGENCY monitor.globalStatus.critical: Power Supply Status Critical: PSU2, PSU1.
node1 EMERGENCY callhome.chassis.overtemp: Call home for CHASSIS OVER TEMPERATURE SHUTDOWN
node1 EMERGENCY callhome.battery.failure: Call home for BATTERY (not present) CRITICAL.
node1 ERROR callhome.chassis.power: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU2, PSU1.
node1 ALERT monitor.chassisPower.degraded: Chassis power is degraded: Power Supply Status Critical: PSU2, PSU1.
node1 EMERGENCY monitor.shutdown.chassisOverTemp: Chassis temperature is too hot: Multiple Internal Temp sensors are unreadable. System will be shutdown in 10 minutes
- 如果 节点上的串行控制台无响应、则多个传感器不可用或无效:
::*>node run -node node1 -command environment status chassis list-sensors
Node: node1
Sensor Name State Current Critical Warning Warning Critical
Reading Low Low High High
NVDIMM0 Health GOOD
LED1 Temp not_available -- C 0 C 3 C 43 C 46 C
LED2 Temp not_available -- C 0 C 3 C 43 C 46 C
MP Temp1 not_available -- C 0 C 5 C 45 C 48 C
MP Temp3 not_available -- C 0 C 5 C 45 C 48 C
Mezz Temp1 invalid -- C 0 C 5 C 80 C 85 C
Mezz Temp2 invalid -- C 0 C 5 C 54 C 57 C
PSU1 VIN invalid -- mV 90480 mV 93600 mV 261040 mV 263120 mV
PSU1 VOUT invalid -- mV 11336 mV 11440 mV 12948 mV 13156 mV
PSU1 Curr IIN invalid -- mA 0 mA -- 9984 mA 12012 mA
PSU1 IOUT invalid -- mA 0 mA -- 130000 mA 132000 mA
PSU1 PIN invalid -- mW 7100 mW 14200 mW 1611700 mW 1796300 mW
PSU1 POUT invalid -- mW 7100 mW 14200 mW 1611700 mW 1796300 mW
PSU1 Inlet invalid -- C 0 C -- 58 C 63 C
PSU1 Hot invalid -- C 0 C -- 100 C 105 C
PSU1 FB Hot invalid -- C 0 C -- 100 C 105 C
PSU1 FAN not_available -- RPM 800 RPM 1200 RPM -- --
PSU2 VIN invalid -- mV 90480 mV 93600 mV 261040 mV 263120 mV
PSU2 VOUT invalid -- mV 11336 mV 11440 mV 12948 mV 13156 mV
PSU2 Curr IIN invalid -- mA 0 mA -- 9984 mA 12012 mA
PSU2 IOUT invalid -- mA 0 mA -- 130000 mA 132000 mA
PSU2 PIN invalid -- mW 7100 mW 14200 mW 1611700 mW 1796300 mW
PSU2 POUT invalid -- mW 7100 mW 14200 mW 1611700 mW 1796300 mW
PSU2 Inlet invalid -- C 0 C -- 58 C 63 C
PSU2 Hot invalid -- C 0 C -- 100 C 105 C
PSU2 FB Hot invalid -- C 0 C -- 100 C 105 C
PSU2 FAN invalid -- RPM 800 RPM 1200 RPM -- --
Fan1_1 not_available -- RPM 600 RPM 900 RPM -- --
Fan1_2 not_available -- RPM 600 RPM 900 RPM -- --
Fan2_1 not_available -- RPM 600 RPM 900 RPM -- --
Fan2_2 not_available -- RPM 600 RPM 900 RPM -- --
Fan3_1 not_available -- RPM 600 RPM 900 RPM -- --
Fan3_2 not_available -- RPM 600 RPM 900 RPM -- --
Fan4_1 not_available -- RPM 600 RPM 900 RPM -- --
Fan4_2 not_available -- RPM 600 RPM 900 RPM -- --
- 在BMC命令行界面
bmc log debug
的""输出中、多个传感器状态为na
[2023-07-04 20:27:26.617] CX5_Temp1 | na | degrees C | na | na | 0.000 | 5.000 | 80.000 | 85.000 | na
[2023-07-04 20:27:26.617] CX5_Temp2 | na | degrees C | na | na | 0.000 | 5.000 | 80.000 | 85.000 | na
[2023-07-04 20:27:26.617] LED1_Temp | na | degrees C | na | na | 0.000 | 3.000 | 43.000 | 46.000 | na
[2023-07-04 20:27:26.617] LED2_Temp | na | degrees C | na | na | 0.000 | 3.000 | 43.000 | 46.000 | na
[2023-07-04 20:27:26.617] MP_Temp1 | na | degrees C | na | na | 0.000 | 5.000 | 45.000 | 48.000 | na
[2023-07-04 20:27:26.667] MP_Temp3 | na | degrees C | na | na | 0.000 | 5.000 | 45.000 | 48.000 | na
[2023-07-04 20:27:29.016] Mezz_Temp1 | na | degrees C | na | na | 0.000 | 5.000 | 80.000 | 85.000 | na
[2023-07-04 20:27:29.016] Mezz_Temp2 | na | degrees C | na | na | 0.000 | 5.000 | 54.000 | 57.000 | na
