跳转到主内容
P3.3v BATT"严重"低"或"高"
25
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
FAS / AFF系统
问题描述
  • EMS日志报告""P3.3V BATT is critical low/high错误。
[env_mgr: monitor.chassispower.degraded:ALERT]: Chassis power is degraded: Sensor detecting voltage anomalies.
[env_mgr: monitor.chassispower.degraded:ALERT]: Chassis power is degraded: P3.3V BATT is critical low (16 mV).
[env_mgr: monitor.chassispower.ok:NOTICE]: Chassis power is OK.
[env_mgr: monitor.chassispower.degraded:ALERT]: Chassis power is degraded: P3.3V BATT is critical high (4064 mV).
  • SP-LATEST-IPMI"日志中、RTC电池的状态为正常值。
===SP-LATEST-IPMI===
/usr/local/bin/ipmi sensors
Sensor Name    |
Current   | Unit     | Status    | LCR     | LNC     | UNC     |
UCR
P3V3_BATT     | 0.160    | Volts    | ok      | 0.016    | 0.032    | 4.048    | 4.064
/usr/local/bin/environ -show_all
Sensor Name        State      Current   Critical    Warning    Warning
Critical                     Reading     Low      Low      High
High
P3.3V BATT normal      160 mV     16 mV     32 mV    4048 mV    4064 mV
New to NetApp?
  • 这篇文章对您有帮助吗?
