跳转到主内容
由于"check-access"命令中的错误代码7208、无法挂载NFS
45
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas<a>用于翻译</a>
Last Updated:
适用场景
  • ONTAP
  • NFS
问题描述
  • 无法挂载、浏览或列出NFS导出的内容。
  • EMS消息包括:
mgwd: exports.hostname.transient:error]: Hostname "hostname.fqdn.com" could not be resolved to an IPv4 address (error 8) when evaluating export-policy rule at index "index #" in policy-id "policy id" on Vserver "vserver".
  • vserver export-policy check-access -vserver <vserver> -client-ip <ip> -volume <vol> -authentication-method sys -protocol nfs3 -access-type read-write 对受影响的客户端运行时出现签名错误消息:
Lookup failed on vserver "vserver" volume "vol" client-ip "client ip" authentication-method "sys" protocol "nfs3" access-type "read-write": Failed to check exports for Vserver "vserver". The command returned an error when evaluating the client match "client.fqdn.com" for rule at index "index number" in export policy "export policy". Error code: 7208. The problem appears to be in the name service configuration for the client match specified in the rule. Wait for a few seconds, and then try the command again. If this error persists, contact technical support personnel for assistance.
New to NetApp?
