跳转到主内容
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
请致电主页,了解电池(容量低)严重问题
9
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
适用于
  • 服务处理器 (SP)
  • AFF A700
问题
  • EMS 报告 ""BATTERY (capacity low) CRITICAL
示例:
[NodeA:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (capacity low) CRITICAL.
  • system sensors show 在 SP 中检查电池状态是否正常。
示例:
Bat_Status       | 0x0        | discrete   | Ready      | na        | na        | na        | na
Bat_Ambient_1    | 25.000     | degrees C  | ok         | 0.000     | 3.000     | 47.000    | 52.000
Bat_Ambient_2    | 25.000     | degrees C  | ok         | 0.000     | 3.000     | 47.000    | 52.000
Bat_Charge_Curr  | 0.000      | Amps       | ok         | na        | na        | 5.500     | 6.000
Bat_Charge_Volt  | 8.150      | Volts      | ok         | na        | na        | 8.350     | 8.400
Bat_Curr         | 0.000      | Amps       | ok         | -0.100    | -0.050    | 2.500     | 3.000
Bat_Cycle_Count  | 12.000     | cycles     | ok         | na        | na        | na        | na
Bat_Design_Cap   | 4.300      | Amps*hour  | ok         | 0.000     | 0.000     | 6.375     | 6.375
Bat_Dstg_Cycles  | 12.000     | cycles     | ok         | 2.000     | 5.000     | na        | na
Bat_Full_Cap     | 3.025      | Amps*hour  | ok         | 2.000     | 2.200     | 4.750     | 5.000
Bat_Initial_Fcc  | 3.275      | Amps*hour  | ok         | 2.000     | 2.200     | 4.750     | 5.000
Bat_Rem_Cap      | 3.025      | Amps*hour  | ok         | 0.250     | 0.500     | 4.750     | 5.000
Bat_Temp         | 24.000     | degrees C  | ok         | -5.000    | 0.000     | 55.000    | 60.000
Bat_Volt         | 8.150      | Volts      | ok         | 6.000     | 6.500     | 8.300     | 8.500
  • ""Learn cycle记录在events allSP 的 "" 中。
示例:
记录 1552 : 2021 年 2 月 22 日星期一 00 : 21 : 19.602467 IPMI.notice]: 7d04 : 02 ; EVT : 6f08ffff ; BAT_Status ;断言事件:" 学习周期"
记录 1553 : 2021 年 2 月 22 日 01 : 31 : 20.286318 ( IPMI.notice]: 7e04 : 02 : EVT : ef08FFFF _ 状态 _ 取消断言事件, "学习周期"
New to NetApp?
Scan to view the article on your device
