跳转到主内容
由于 SFP 类型不正确而导致 CRC 错误使用的是 AFR-57F5MZ-NA1
65
Visibility:
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
适用于
  • AFF A300
  • ONTAP 9.x
  • AFR-57F5MZ-NA1
问题
IFstat 日志存在以下错误:
 -- interface e0b (181 days, 0 hours, 30 minutes, 5 seconds) -- RECEIVE Total frames: 87552k | Frames/second: 6 | Total bytes: 16679m Bytes/second: 1066 | Total errors: 11430 | Errors/minute: 0 Total discards: 0 | Discards/minute: 0 | Multi/broadcast: 2567k Non-primary u/c: 0 | CRC errors: 11352 | Runt frames: 0 Fragment: 0 | Long frames: 0 | Jabber: 16 Length errors: 62 | No buffer: 0 | Xon: 0 Xoff: 0 | Pause: 0 | Jumbo: 419k Noproto: 0 | Error symbol: 2300 | Illegal symbol: 1300 Bus overruns: 0 | Queue drops: 0 | LRO segments: 55499k LRO bytes: 12918m | LRO6 segments: 0 | LRO6 bytes: 0 Bad UDP cksum: 0 | Bad UDP6 cksum: 0 | Bad TCP cksum: 0 Bad TCP6 cksum: 0 | Mcast v6 solicit: 0 TRANSMIT Total frames: 154m | Frames/second: 10 | Total bytes: 63809m Bytes/second: 4080 | Total errors: 0 | Errors/minute: 0 Total discards: 0 | Queue overflow: 0 | Multi/broadcast: 15711k Xon: 0 | Xoff: 0 | Pause: 0 Jumbo: 0 | Cfg Up to Downs: 0 | TSO non-TCP drop: 0 Split hdr drop: 0 | Timeout: 0 | TSO segments: 2893k TSO bytes: 9533m | TSO6 segments: 0 | TSO6 bytes: 0 HW UDP cksums: 0 | HW UDP6 cksums: 0 | HW TCP cksums: 0 HW TCP6 cksums: 0 | Mcast v6 solicit: 0 DEVICE Mcast addresses: 3 | Rx MBuf Sz: 4096 LINK INFO Speed: 10000M | Duplex: full | Flowcontrol: full Media state: active | Up to downs: 1
New to NetApp?
  • 这篇文章对您有帮助吗?
