跳转到主内容
CPU0 温度传感器显示故障
17
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • 服务处理器 (SP)
问题描述
CPU0 Temp 中的传感器显示 FAILED 。 SP-LATEST-IPMI
CPU0 Temp Avg            failed            -- C        --          --         -11 C        -1 C
InFlow Temp Avg          normal            23 C         0 C         5 C        50 C        55 C
OutFlow Temp Avg         normal            37 C         0 C         5 C        65 C        75 C
PCI Temp Avg             normal            32 C         0 C         5 C        60 C        70 C
Bat Temp Avg             normal            30 C         0 C         5 C        60 C        70 C
Amb2 Temp Avg            normal            22 C         0 C         5 C        47 C        52 C
Amb1 Temp  Avg           normal            22 C         0 C         5 C        47 C        52 C
PSU2 FRU Fan                                OK
PSU2 FRU Power                              ON
PSU1 FRU Fan                                OK
PSU1 FRU Power                              ON
Fan3 INFO                               FRU_AVAIL
Fan2 INFO                               FRU_AVAIL
Fan1 INFO                               FRU_AVAIL
PSU1 INFO                               FRU_AVAIL
PSU1 INFO                               FRU_AVAIL
Fan1                                      GOOD
Fan2                                      GOOD
Fan3                                      GOOD
PSU1                                      GOOD
PSU2                                      GOOD
CPU0 Temp Margin         failed            -- C        --          --         -11 C        -1 C
In Flow Temp             normal            23 C         0 C         5 C        50 C        55 C
Out Flow Temp            normal            37 C         0 C         5 C        65 C        75 C
PCI Slot Temp            normal            32 C         0 C         5 C        60 C        70 C
Smart Bat Temp           normal            30 C         0 C         5 C        60 C        70 C
CPU0 Error                              NORMAL
New to NetApp?
  • 这篇文章对您有帮助吗?
