跳转到主内容
已取消自动关闭序列
157
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
  • FAS8300
  • FAS8700
  • BMC FW 13.5
问题描述
  • 系统生成以下AutoSupport警报
Call home for BATTERY (wrong charge) WARNING.
  • EMS日志中会显示以下消息
[Node-01: env_mgr: nvmem.battery.wrongCharge:alert]: The NVMEM battery charger is charging the battery even though the battery is not requesting to be charged. To prevent data loss, the system will shut down in 24 hours.
[Node-01: env_mgr: callhome.battery.warning:alert]: Call home for BATTERY (wrong charge) WARNING.
[Node-01: env_mgr: nvmem.battery.normalCharge:notice]: The NVMEM battery charging status is normal.
[Node-01: env_mgr: monitor.shutdown.cancel:notice]: Automatic shutdown sequence canceled.
  • BMC固件已升级到13.5
    • 不再显示NVMEM电池消息
  • 仍会记录以下消息:
Sun Aug 22 08:46:18 +0200 [Node-01: env_mgr: monitor.shutdown.cancel:notice]: Automatic shutdown sequence canceled.
Sun Aug 22 09:46:19 +0200 [Node-01: env_mgr: monitor.shutdown.cancel:notice]: Automatic shutdown sequence canceled.
Sun Aug 22 10:46:19 +0200 [Node-01: env_mgr: monitor.shutdown.cancel:notice]: Automatic shutdown sequence canceled
New to NetApp?
