跳转到主内容
更换主板后,PCM 无法启动,并显示安装了错误的 NVMEM 电池的消息
150
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • AFF A400、AFF C400、ASA A400、ASA C400、FAS8700、FAS8300
  • AFF C190,AFF A150, AFF A220,ASA A150,FAS2750,FAS2720
  • AFF A800、AFF C800、ASA A800、ASA C800
问题描述
  • 在"适用于"部分中的型号更换主板 (PCM) 后,在引导过程中出现以下错误:
Apr 27 08:31:18 [Node1:nvmem.battery.unread:EMERGENCY]: The NVMEM battery state cannot be determined because the 'Bat Initial FCC' sensor is unreadable. To prevent data loss, the system will shut down in 5 minutes.
Apr 27 08:31:18 Power outage protection flash de-staging: 28 cycles
WARNING:  The battery is unfit to retain data during a power
          outage.  This is likely because the battery is
          discharged but could be due to other temporary
          conditions.
          When the battery is ready, the boot process will
          complete and services will be engaged.
          To override this delay, press 'c' followed by 'Enter'
Apr 27 08:32:18 [Node1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Initial FCC' unreadable) CRITICAL.
Apr 27 08:32:19 [Node1:nvmem.battery.packInvalid:EMERGENCY]: The incorrect NVMEM battery is installed. Expected part number is 271-00045. To prevent data loss, the system will shut down in 5 minutes.
Apr 27 08:32:49 [Node1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (invalid pack) CRITICAL.
* Power Fail - Please Wait *
WARNING:  The battery is experiencing a critical failure:
      - Invalid battery pack is detected
      Without a working battery, the system cannot retain data
      during a power outage, which can result in data loss.
      Power down the system and verify that the battery is
      properly installed.
      To ignore this failure and boot the system in a mode
      where data loss might occur, press 'c' followed by 'Enter'
  • 该节点继续关闭。
New to NetApp?
