跳转到主内容
由于自动启动映像失败, ANDU 已暂停。无法识别文件系统( -29 )
56
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
core
Last Updated:
适用场景
  • FAS2552
  • FAS2554
  • ONTAP 9
问题描述
andu 操作将暂停,并显示类似以下内容的消息:
cluster_CLI::> cluster image show-update-progress
                         Estimated      Elapsed
Update Phase      Status           Duration     Duration
Pre-update checks   completed         00:10:00     00:00:35
Data ONTAP updates   paused-on-error      01:23:00     00:37:18
Details:
Node name       Status       Status Description
node-01      waiting
node-02      failed       Error: Node "node-02" is not in
                    "waiting for giveback" state.
                    Action: Use the "storage failover
                    show" to verify that node
                    "node-02" is in one of the
                    following states: "waiting for
                    giveback" or "connected".
4 entries were displayed.
Status: Paused - An error occurred in "Data ONTAP updates" phase. The update cannot continue until the error has been
         resolved. Resolve all issues, then use the "cluster image resume-update" command to resume the update
从受影响节点的 SP 日志中,出现无法启动新默认映像的情况:
 Boot Loader version 4.3 Copyright (C) 2000-2003 Broadcom Corporation. Portions Copyright (C) 2002-2014 NetApp, Inc. All Rights Reserved. CPU Type: Intel(R) Xeon(R) CPU C3528 @ 1.73GHz Starting AUTOBOOT press Ctrl-C to abort... File system not recognized (errcode=-29) Trying to boot from alternative path:fat://boot0/X86_64/kernel/primary.krn Autoboot the image failed. File system not recognized (-29)
通过 LOADER> SP 登录时,节点将显示提示符。
New to NetApp?
