由于不存在NVMEM电池、AFF A400/FAS8300将关闭
适用场景
- AFF A400
- FAS 8300
- FAS 8700
- ONTAP 9
问题描述
- 节点关闭、报告NVRAM电池不存在
Thu Feb 03 13:57:59 +0000 [node-01: env_mgr: nvmem.battery.notPresent:alert]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
Thu Feb 03 14:00:00 +0000 [node-01: statd: monitor.nvramLowBattery:EMERGENCY]: NVRAM battery is dangerously low.
或
Sat Apr 23 19:49:50 +0300 [node-01: env_mgr: nvmem.battery.noCharge:alert]: The NVMEM battery is requesting to be charged but the charger is not charging the battery. To prevent data loss, the system will shut down in 20 minutes.
Sat Apr 23 19:50:50 +0300 [node-01: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (no charge) CRITICAL.
Sat Apr 23 20:09:50 +0300 [node-01: statd: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery not charging)
- 蓄电池传感器故障:
Sensor Name Sensor Type Sensor State
Bat Charging State discrete fault
Battery Charge discrete failed
Battery Charge Failed? discrete fault
- 启动时的控制台消息:
WARNING: The battery is experiencing a critical failure:
- Battery is not present
Without a working battery, the system cannot retain data
during a power outage, which can result in data loss.
Power down the system and verify that the battery is
properly installed.
To ignore this failure and boot the system in a mode
where data loss might occur, press 'c' followed by 'Enter'
May 03 20:34:08 [node-01:nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
May 03 20:34:08 [node-01:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
- 尝试登录BMC失败、并显示以下消息:
/usr/local/bin/systemshell: Too many open files in system
