A800 机箱温度过高:环境温度警告为高
适用场景
- AFF A800
问题描述
- 此时将生成并清除以下警报:
[node1: env_mgr: monitor.shutdown.chassisOverTemp:EMERGENCY]: Chassis temperature is too hot: Ambient temperature is warning high. System will be shutdown in 2 minutes
[node1: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: LED Board Temp1 is warning high (43 C).
[node1: env_mgr: monitor.shutdown.cancel:notice]: Automatic shutdown sequence canceled.
[node1: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
