跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
7- 模式自动升级磁盘固件失败
22
Visibility:
Votes:
2
Category:
data-ontap-8
Specialty:
hw
Last Updated:
适用于
  • FAS 系列
  • Data ONTAP 7-模式
问题
升级 7- 模式 HA 的磁盘固件。
一个节点升级失败。
示例
磁盘 X412_SSKBE560A15 从 NA00 到 NA02 ,
升级信息仅显示在节点 B 中
Fri Aug  7 19:30:16 CST [FAS6210-5048-B:raid.disk.offline:notice]: Marking Disk 1c.125L70 Shelf 60 Bay 17 [NETAPP   X412_SSKBE560A15 NA01] S/N [WFJ1WQTJ] offline.
Fri Aug  7 19:30:16 CST [FAS6210-5048-B:bdfu.selected:info]: Disk 1c.125L70 [NETAPP   X412_SSKBE560A15 NA01] S/N [WFJ1WQTJ] selected for background disk firmware update.
Fri Aug  7 19:30:16 CST [FAS6210-5048-B:dfu.firmwareDownloading:info]: Now downloading firmware file /etc/disk_fw/X412_SSKBE560A15.NA02.LOD on 1 disk(s) of plex [Pool0]...
Fri Aug  7 19:30:34 CST [FAS6210-5048-B:raid.disk.online:notice]: Onlining Disk 1c.125L70 Shelf 60 Bay 17 [NETAPP   X412_SSKBE560A15 NA01] S/N [WFJ1WQTJ].
但是storage show disk ,命令输出表明这些磁盘使用的是固件 NA00 。重新启动控制器和 / 或重新拔插磁盘架模块不会帮助解决此问题。
New to NetApp?
Scan to view the article on your device
