SP 重新启动后, "system node service-processor " 将显示降级状态
适用场景
- FAS8020
- FAS8040
- FAS2620
- FAS2650
- FAS8200
- Data ONTAP 9
- Data ONTAP 8
问题描述
- 重新启动服务处理器( SP )后, SP 将更改为已降级状态。
集群:: * > system node service-processor reboot-sp -node *
Note: If your console connection is through the SP, it will be disconnected.
Do you want to reboot the SP ? {y|n}: y
2 entries were acted on.
Cluster::*>
Cluster::*> system node service-processor
autosupport image network reboot-sp show snmp
Cluster::*> system node service-processor show
IP Firmware
Node Type Status Configured Version IP Address
node-1 SP rebooting false 3.0.2 -
node-2 SP rebooting false 3.0.2 -
IP Firmware
node-1 SP online false 3.0.2 -
IP Firmware
node-2 SP unknown false 3.0.2 -
IP Firmware
node-2 SP degraded true 3.0.2 0.0.0.0
Cluster::> sp ervice-p r processor show
(system node service-processor show)
IP Firmware
node-2 SP offline true 3.0.2 0.0.0.0
node-1
" 开始接管,因为node-2
" 的 SP 脱机。
Cluster::> Feb 20 09:53:59 [node-2:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (SP IPMI Dead)
Waiting for PIDS: /usr/sbin/ypbind 729.
Waiting for PIDS: 695.
Terminated
Uptime: 28d13h49m5s
System powering down...
System halting...
BIOS version: 9.3
Portions Copyright (c) 2011-2014 NetApp. All Rights Reserved
Waiting for SP ...
SP failure. Resetting SP from primary FW. This can take a few minutes
Waiting for SP ...
SP failure. Resetting SP from backup FW. This can take a few minutes
Waiting for SP ...
Failed to recover SP
IPMI PCI Slot Control failed.
IPMI:Get controller FRU inventory:failed
Phoenix SecureCore Tiano(TM)
Copyright 1985-2021 Phoenix Technologies Ltd.
All Rights Reserved
Build Date: 12/02/2014
* 9.3 *
* PHOENIX SC-T 2009-2021 *
CPU = 1 Processor(s) Detected, Cores per Processor = 8
Intel(R) Xeon(R) CPU E5-2658 @ 2.10GHz
32768 MB System RAM Installed
256 KB L2 Cache
System BIOS shadowed
Video BIOS shadowed
USB Device: MICRON eUSB DISK
Boot Loader version 5.3
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2014 NetApp, Inc. All Rights Reserved.
BIOS POST Failure(s) detected: SP IPMI failure. Abort AUTOBOOT
- 拔下并重新插入 ""
node-2
无法清除此错误。
LOADER-B> BIOS version: 9.3
Waiting for SP ...
Waiting for SP ...
Waiting for SP ...
All Rights Reserved
* 9.3 *
256 KB L2 Cache
Video BIOS shadowed
