"storage show fault"显示磁盘架中的电源出现故障
适用场景
- DS4246
- 重新拔插故障电源未解决此问题描述
问题描述
""storage show fault
显示磁盘架中的电源出现故障。
示例:
Customer Problem Summary :
Enclosure Status: critical
Channel: 0c
Shelf: 34
Shelf Type: DS4246
Product Serial Number: SHJSGXXXXXXXXXX
Module Type: IOM6
Power Supplies:
Element Status Status Bytes Status Descriptions
1: CRITICAL 02,00,00,F0 OFF, RQSTED ON, FAIL
2: OK 01,00,00,20 RQSTED ON
3: NOT INSTALLED 05,00,00,20
4: OK 01,00,00,20 RQSTED ON
