跳转到主内容
"system service-event show" 显示 "P1V05_PCH_STBY :电压传感器 16 LNC"
53
Visibility:
Votes:
2
Category:
fas-systems<a>2008906522</a>
Specialty:
hw
Last Updated:
适用场景
  • AFF A800
  • 底板管理控制器( BMC )
问题描述
  • system service-event show 显示 P1V05_PCH_STBY: Voltage Sensor 16 LNC
  • 系统事件日志(SEL)中的BMC IPMI通知会将 P1V05_PCH_STBY 传感器报告为 Lower Non-critical going low.
示例:
Record 1885: Fri Sep 03 07:54:32.800000 2021 [IPMI.notice]: 0415 | 02 | EVT: 01509191 | P1V05_PCH_STBY | Assertion Event, "Lower Non-critical going low " | Reading: 0.986 | Threshold: 0.986
  • P1V05_PCH_STBY IPMI传感器输出状态 正常
示例:
Sensor Name      | Current    | Unit       | Status     | LCR       | LNC       | UNC       | UCR-----------------+------------+------------+------------+-----------+-----------+-----------+-----------
PVCCIN_CPU0      | 1.733      | Volts      | ok         | 0.011     | 0.021     | 2.457     | 2.468
PVCCIN_CPU1      | 1.733      | Volts      | ok         | 0.011     | 0.021     | 2.457     | 2.468
PVCCIO_CPU0      | 0.966      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
PVCCIO_CPU1      | 0.972      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
PVDDQ_ABC        | 1.156      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
PVDDQ_DEF        | 1.156      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
PVDDQ_GHJ        | 1.156      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
PVDDQ_KLM        | 1.156      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
PVTT_ABC         | 0.564      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
PVTT_DEF         | 0.564      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
PVTT_GHJ         | 0.564      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
PVTT_KLM         | 0.564      | Volts      | ok         | 0.014     | 0.020     | 1.707     | 1.734
P3V3_BMC         | 3.218      | Volts      | ok         | 2.958     | 3.045     | 3.564     | 3.668
P1V8_PCH_STBY    | 1.700      | Volts      | ok         | 0.938     | 0.993     | 2.312     | 2.380
PVNN_PCH_STBY    | 0.945      | Volts      | ok         | 0.891     | 0.925     | 1.156     | 1.190
P1V05_PCH_STBY   | 0.993      | Volts      | ok         | 0.938     | 0.986     | 1.102     | 1.149
  • 控制器故障LED亮起。
New to NetApp?
