跳转到主内容
“ System Health Alert Show ”报告节点中的服务处理器没有网络连接
9
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
状态信息
适用于
  • ONTAP 9
  • 服务处理器 (SP)
问题
系统在“system health alert show”中出现关于 SP 没有网络连接的错误。
示例:
cluster1::> system health alert show
               Node: node1
           Resource: SP Config
           Severity: Major
    Indication Time: Tue Aug 27 23:50:13 2019
           Suppress: false
        Acknowledge: false
     Probable Cause: Service Processor in node node1 has no network
                    connectivity.The cable between the Wrench port on the
                     controller and the ethernet switch is disconnected.
    Possible Effect: You might not be able to use the Service Processor to
                     remotely access, monitor, and troubleshoot your
                     storage system.
Corrective Actions: 1. Check the connection between the Wrench port and the ethernet switch.
                     2. If the cable is properly connected, ensure that the Service Processor's ethernet interface is configured properly by executing the command "system service-processor network show".
                     3. Check for network cable related issues.
                     4. Contact the technical support if the alert persists.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
