跳转到主内容
在 ADP 配置中更换磁盘后, "sysconfig -r" 不会显示已更换的磁盘
13
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
  • 高级磁盘分区( ADP )
  • ONTAP 9
  • AFF 和 FAS
问题描述
  • 在 ADP 环境中更换磁盘后, "sysconfig -r" " 不会显示更换的磁盘。
  • ""sysconfig -a显示了已更换的磁盘。
更换前:
      00.2 : NETAPP   X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXG5)
      00.3 : NETAPP  X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXRF) (Failed)
      00.4 : NETAPP   X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXET)
更换后:
      00.3 : NETAPP  X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXBE)
  •   storage disk show -partition-ownership 在输出中,根和数据为空, disk show -n 并且 Not Owned 为状态。
::*> storage disk show -partition-ownership
2.0.3   Container node-a     node-a     538164682   538164682
     Root    -          -          -       -
     Data    -          -          -       -       -          - -
::*> disk show -n
  DISK     OWNER           POOL   SERIAL NUMBER      HOME           DR HOME
0b.00.3P1   Not Owned         NONE   WBXXXXXXXX001
0b.00.3P2   Not Owned         NONE   WBXXXXXXXX002
New to NetApp?
Scan to view the article on your device
