跳转到主内容
ic.HAInterconnectLinkDown 频繁发生
257
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
hw
Last Updated:
仅在指定的内容块内添加文本。单击此处 查看有关创建解决循环内容的更多信息。
适用于
  • ONTAP 9
  • AFF-A400
  • FAS8300
  • FAS8700
  • HA 互连
问题
  • "system ha interconnect status show" 出现 link 0link 1 处于关闭状态。
Cluster::*> system ha interconnect status show
           Node:node-1
       Link 0 Status: down
       Link 1 Status: down
     Is Link 0 Active: false
     Is Link 1 Active: false
 IC RDMA Connection: up
           Node:node-2
       Link 0 Status: down
       Link 1 Status: down
2 entries were
displayed.
  • EMS 日志每 1 小时报告一次"ic.HAInterconnectLinkDown"。
[?] Thu Apr 28 02:00:00 +0000 [node-1: statd: ic.HAInterconnectLinkDown:error]: HA interconnect: External link #0 has been down for 73387 minutes.
[?] Thu Apr 28 03:00:00 +0000 [node-1: statd: ic.HAInterconnectLinkDown:error]: HA interconnect: External link #0 has been down for 73447 minutes.
[?] Thu Apr 28 04:00:00 +0000 [node-1: statd: ic.HAInterconnectLinkDown:error]: HA interconnect: External link #0 has been down for 73507 minutes.
[?] Thu Apr 28 05:00:00 +0000 [node-1: statd: ic.HAInterconnectLinkDown:error]: HA interconnect: External link #0 has been down for 73567 minutes.
[?] Thu Apr 28 02:00:00 +0000 [node-2: statd: ic.HAInterconnectLinkDown:error]: HA interconnect: External link #0 has been down for 73309 minutes.
[?] Thu Apr 28 03:00:00 +0000 [node-2: statd: ic.HAInterconnectLinkDown:error]: HA interconnect: External link #0 has been down for 73429 minutes.
[?] Thu Apr 28 04:00:00 +0000 [node-2: statd: ic.HAInterconnectLinkDown:error]: HA interconnect: External link #0 has been down for 73489 minutes.
[?] Thu Apr 28 05:00:00 +0000 [node-2: statd: ic.HAInterconnectLinkDown:error]: HA interconnect: External link #0 has been down for 73549 minutes.
  • node-1 "sysconfig -a" e0a SFP 信息为空。
slot 0: 10G/25G Ethernet Controller CX5
  e0a MAC Address:   d0:39:ea:38:fb:bb (auto-unknown-fd-down)
    SFP Vendor:
    SFP Part Number:
    SFP Serial Number:
  e0b MAC Address:   d0:39:ea:38:fb:bc (auto-25g_cr-fd-up)
    SFP Vendor:      Molex
    SFP Part Number:   1111455002
    SFP Serial Number:  XXXXXXXXXXXXXX
  Device Type:     CX5 PSID(NAP0000000006)
  Firmware Version:   16.26.4012
原因
  • 未正确读取 Interconnect 中的 SFP 信息
  • Interconnect 电缆或板载端口硬件故障
解决方案
  1. 检查并重新拔插 node-1 e0a 和 node-2 e0a SFP 电缆。
  2. 如果重新拔插电缆无法解决此问题,请更换 node-1 e0a 到 node-2 e0a SFP 电缆。
  3. 如果更换 SFP 电缆无法解决上述问题,请从 node-2 执行接管。
  4. 执行 CFO 回馈并执行本地环回测试以确定哪个节点是问题的原因。
  5. 要获得更多帮助,请联系 NetApp 技术支持 并参考本文。
追加信息
追加信息_text
内部参考
  • 在处理与 HA IC 端口和 HA 集群端口相关的问题时,仅凭 LED 状态不足以确定哪一侧出现故障。
  • 以下所有步骤对于确定故障方都很重要。
  1. 重新拔插电缆
  2. 更换电缆
  3. 环回测试
  4. 检查 ASUP 日志
示例:
案例# 2009500112
  • 当我们进行网络电缆重新插拔测试时,node1 的端口 e0b 上的 LED 未点亮(off),而 node2 的端口 e0b 上的 LED 持续绿色
  • 因此,我们认为 node1 的网络端口有问题。
  • 然而,后来的事实证明,是 node2 的网络端口问题导致 node1 的网络端口上的 LED 熄灭。
  • 在此示例中,sysconfig -a 输出包含关键信息,即 node2 的端口信息缺少 SFP 相关信息
Node1
  e0a MAC Address:   d0:39:ea:xx:xx:xx (auto-25g_cr-fd-up)
    SFP Vendor:      Molex
    SFP Serial Number:  xxxxxxxxxxxxx
  e0b MAC Address:   d0:39:ea: xx:xx:xx (auto-unknown-fd-down)
    SFP Vendor:      Molex
Node2
  e0a MAC Address:   d0:39:ea: xx:xx:xx (auto-25g_cr-fd-up)
    SFP Vendor:      Molex
    SFP Vendor:
    SFP Part Number:
    SFP Serial Number:
New to NetApp?
