" 正在等待集群应用程序在本地联机 节点 "
适用于
- FAS2650
- ONTAP 9
- 服务处理器 (SP)
问题
- 在系统上发生接管后
Waiting for cluster applications to come online on the local node.
,将显示消息 " " ,并且无法交还。
示例:
::> storage failover show
Takeover
Node Partner Possible State Description
fas2650-a fas2650-b true Connected to fas2650-b
fas2650-b fas2650-a true Connected to fas2650-a. Waiting for cluster applications to come online on the local node.
2 entries were displayed.
manage::> set diag -co off
manage::*> cluster kernel-service show
Master Cluster Quorum Availability Operational
Node Node Status Status Status
fas2650-a fas2650-a in-quorum true operational
fas2650-b out-of-quorum false unknown
fas2650-b fas2650-a out-of-quorum false operational
fas2650-b out-of-quorum true operational
4 entries were displayed.
ura-fas2650-manage::*> cluster kernel-service node show
Is Cluster
Node Master Node Status Status Status
fas2650-a true fas2650-a in-quorum true operational
fas2650-b true fas2650-a out-of-quorum false operational
manage::> storage failover giveback -ofnode fas2650-b -override-vetoes true
Warning: Initiating a giveback with vetoes overridden will result in giveback
proceeding even if the node detects outstanding issues that would make
a giveback dangerous or disruptive. Do you want to continue?
{y|n}: y
Error: command failed: Failed to initiate giveback. Reason: A giveback is
already in progress.
- EMS 日志显示在 "
bsdsocket
" 错误和 "SPLinkDownAlert
消息之后。
示例:
[?] Fri Jul 10 18:34:40 JST [fas2650-a: kernel: bsdsocket.queueLimit.reached:error]: Number of connection requests for the socket bound to port 935 having the IP address * has reached the limit of 1536 connections. The socket uses TCP protocol. This event has occurred 62 times since the last warning.
[?] Fri Jul 10 18:35:16 JST [fas2650-a: dsa_vmm: hamsg.noSend:debug]: params: {'req_op': '6', 'remoteID': 'bb7f5031722311e7ab45a7880059a5e9', 'status': '1', 'scope_err': '0', 'scope': '16'}
[?] Fri Jul 10 18:40:00 JST [fas2650-a: kernel: bsdsocket.queueLimit.reached:error]: Number of connection requests for the socket bound to port 935 having the IP address * has reached the limit of 1536 co
nnections. The socket uses TCP protocol. This event has occurred 49 times since the last warning.
[?] Fri Jul 10 18:40:41 JST [fas2650-a: dsa_vmm: hamsg.noSend:debug]: params: {'req_op': '6', 'remoteID': 'bb7f5031722311e7ab45a7880059a5e9', 'status': '1', 'scope_err': '0', 'scope': '16'}
[?] Fri Jul 10 18:45:13 JST [fas2650-a: spmd: spm.servprocd.process.exit:alert]: Service processor daemon (servprocd) with ID 4174 exited as a result of normal exit (1). This server will attempt to restart.
[?] Fri Jul 10 18:45:15 JST [fas2650-a: servprocd: mdb.recovery.successful:debug]: params: {'name': 'servprocd'}
[?] Fri Jul 10 18:46:06 JST [fas2650-a: dsa_vmm: hamsg.noSend:debug]: params: {'req_op': '6', 'remoteID': 'bb7f5031722311e7ab45a7880059a5e9', 'status': '1', 'scope_err': '0', 'scope': '16'}
[?] Fri Jul 10 18:50:19 JST [fas2650-a: nphmd: hm.alert.cleared:info]: params: {'alert_id': 'SPLinkDownAlert', 'alerting_resource': 'SP Config', 'detailed_info': 'Alert Id = SPLinkDownAlert , Alerting Resource = SP Config', 'monitor': 'controller'}
