跳转到主内容
尝试擦除集群系统的配置时、出现"未找到本地磁盘"错误
65
Visibility:
Votes:
2
Category:
fas-systems<a>2008519867</a>
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
  • 新建设置
  • 存储
问题描述
  • 首先初始化的节点可以正常启动。
  • 尝试擦除配对节点上的配置时、出现以下错误。
示例:
 * Press Ctrl-C for Boot Menu. *
 Attempting to use existing varfs on /dev/nvrd1
 No SVM keys found.
 Boot Menu will be available.
 Firewall rules loaded.
 Battery charge capacity: 3584 mA*hr. Power outage protection flash de-staging cycles: 51
 Please choose one of the following:
 (1) Normal Boot.
 (2) Boot without /etc/rc.
 (3) Change password.
 (4) Clean configuration and initialize all disks.
 (5) Maintenance mode boot.
 (6) Update flash from backup config.
 (7) Install new software first.
 (8) Reboot node.
 Selection (1-8)? 4
Zero disks, reset config and install a new file system?: yes
This will erase all the data on the disks, are you sure?: yes
Rebooting to finish wipeconfig request
 Assigned 0 out of 3 disks requestedfm_run0: no local disks found & OFW channel is not up.
 [localhost:cf.fm.noMBDisksOrIc:error]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
 WARNING: there do not appear to be any disks attached to the system.
 System halting...
 BIOS version: 9.5
 Portions Copyright (c) 2011-2014 NetApp. All Rights Reserved
 Phoenix SecureCore Tiano(TM)
 Copyright 1985-2020 Phoenix Technologies Ltd.
 All Rights Reserved
  • disk show -v 在维护模式下执行命令、检查是否已将所有磁盘分配给初始化的节点。
示例:
*> disk show -v
 Local System ID: 123456789
   DISK       OWNER                    POOL   SERIAL NUMBER         HOME                     DR HOME                CHKSUM
 0d.13.5                (987654321)    Pool0  Z1ZBB111           (987654321)                          Block
 0d.12.2                (987654321)    Pool0  Z1ZBB222           (987654321)                          Block
 0d.12.1                (987654321)    Pool0  Z1ZBB333           (987654321)                          Block
 0d.12.4                (987654321)    Pool0  Z1ZBB444           (987654321)                          Block
 0d.13.22               (987654321)    Pool0  Z1ZBB555           (987654321)                          Block
New to NetApp?
