跳转到主内容
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
"Chassis temperature is too warm : HIC2 Temp1 is warning high ( 101 C ) " 警报
3
Visibility:
Votes:
0
Category:
fas-systems<a>2009 年 12 月 30 日 8.</a>
Specialty:
hw
Last Updated:
适用场景
  • FAS500f
  • 基板管理控制器( Baseboard Management Controller , BMC )固件 15.4%
问题描述
  • 节点报告 "CHASSIS OVER TEMPERATURE每小时。
  • 可以在事件日志中发现以下错误。
 [env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: HIC2 Temp1 is warning high (101 C).
 [monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
 [env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
  • "SP-LATEST-IPMI环境平台传感器输出为:
HIC1_TEMP0     | 79.000    | degrees C  | ok   | 1.000    | 3.000    | 5.000    | 101.000   | 103.000   | 105.000
HIC1_TEMP1     | 81.000    | degrees C  | ok   | 1.000    | 3.000    | 5.000    | 101.000   | 103.000   | 105.000
HIC2_TEMP0     | 93.000    | degrees C  | ok   | 1.000    | 3.000    | 5.000    | 101.000   | 103.000   | 105.000
HIC2_TEMP1     | 101.000   | degrees C  | nc   | 1.000    | 3.000    | 5.000    | 101.000   | 103.000   | 105.000
Sysfan1_F1_Speed | 9516.000   | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
Sysfan1_F2_Speed | 10296.000  | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
Sysfan2_F1_Speed | 9204.000   | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
Sysfan2_F2_Speed | 9984.000   | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
Sysfan3_F1_Speed | 9516.000   | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
Sysfan3_F2_Speed | 10296.000  | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
Sysfan4_F1_Speed | 9204.000   | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
Sysfan4_F2_Speed | 9984.000   | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
Sysfan5_F1_Speed | 9204.000   | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
Sysfan5_F2_Speed | 10296.000  | RPM     | ok   | 0.000    | 936.000   | 2964.000  | 33072.000 | 34008.000 | 34944.0
New to NetApp?
Scan to view the article on your device
