跳转到主内容
由于电源线电压低,发生 " 机箱电源已降级 " 事件
72
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
适用于
  • FAS8300
  • 底板管理控制器( BMC )
问题
重复发生机箱电源降级事件并带有 ""Power Supply Status Critical: PSU1 & PSU2
从事件日志:
FAS8300AHA02-02  ERROR         callhome.chassis.power: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1.
FAS8300AHA02-02  ALERT         monitor.chassisPower.degraded: Chassis power is degraded: Power Supply Status Critical: PSU1.
FAS8300AHA02-01  EMERGENCY     monitor.globalStatus.critical: Power Supply Status Critical: PSU2.
FAS8300AHA02-01  ERROR         callhome.chassis.power: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU2.
FAS8300AHA02-01  ALERT         monitor.chassisPower.degraded: Chassis power is degraded: Power Supply Status Critical: PSU2.
FAS8300AHA02-02  EMERGENCY     monitor.globalStatus.critical: Power Supply Status Critical: PSU2.
FAS8300AHA02-02  EMERGENCY     monitor.globalStatus.critical: Power Supply Status Critical: PSU1, PSU2.
从 BMC SEL 事件日志:
      c4 | 01/06/2021 | 06:24:16 | Voltage #0x5a | Lower Non-critical going low
      c5 | 01/06/2021 | 06:24:52 | Voltage #0x50 | Lower Non-critical going low
      c6 | 01/06/2021 | 06:25:18 | Voltage #0x50 | Lower Non-critical going low
      c7 | 01/06/2021 | 06:25:37 | Voltage #0x5a | Lower Non-critical going low
New to NetApp?
  • 这篇文章对您有帮助吗?
