未分配的 FIPS 替代驱动器报告不兼容
适用场景
SANtricity OS 11.70 及更低版本
问题描述
- ASUP
recovery-guru-procedures.html
文件具有一个条目SECURITY_GET_
KEY
- 更换未分配的 FIPS 驱动器后,更换驱动器状态
Incompatible
是由于invalid security key
Drive at Shelf 0, Bay 1
Status: Incompatible
Cause: FIPS drive security locked
Mode: Incompatible
Drive capabilities: Data Assurance (DA), FIPS Compliant
Security capable: Yes, FIPS Compliant (FIPS 140 - 2)
Secure-Enabled: Yes
Read/write accessible: No, invalid security key
Drive security key identifier
