两线接口总线故障
适用于
- E2800
- E5700
- SANtricity 11.30.3 或更高版本
问题
- Recovery Guru 报告故障条目如下所示:
示例:
Failure Entry 1: FAILED_TWI_BUS-Recovery Failure Type Code: 380- 主要事件日志报告严重错误,如下所示:
示例:
Date/Time: 3/1/21, 1:23:45 PMSequence number: 1234Event type: 2304Event category: ErrorPriority: CriticalEvent needs attention: trueEvent send alert: trueEvent visibility: trueDescription: Two wire interface bus failureEvent specific codes: 0/0/0Component type: ControllerComponent location: Shelf 99, Bay BLogged by: Controller in bay B
