在utlSlistFrame.h中、E系列控制器意外重新启动、并出现断言失败异常
适用场景
- NetApp E 系列
- SANtricity OS 11.70
问题描述
- E系列控制器意外重新启动并生成核心转储。可以在MAJI-EVal-LOG文件下找到以下事件:
A:3/15/22, 11:56:11 AM (11:56:11) 1301 3704 Core dump retrieval has completed - None
A:3/15/22, 11:55:57 AM (11:55:57) 1300 3703 Core dump retrieval has started - None
- E系列支持日志在
state-capture-data
excLogShow
命令输出下的文件中包含以下异常:
---- Log Entry #0 (Core 0) Mar-10-2022 10:50:21 AM ----
03/10/22-16:46:40 (domTask2): ASSERT: Assertion failed: base != 0, file /u/symsm/ccm_wa/symbios/RAIDCore-4968.1.11/m1_871_debian-4968.1.11/images/m1_e30_871_280x-08.71.03.00/eos/Application/RAIDLib/utlSlistFrame.h, line 159
2022-03-10 16:46:44.289977
Backtrace of the crashed thread:
#0 0x00007fbd0d486067 in raise () from /lib/x86_64-linux-gnu/libc.so.6
No symbol table info available.
#1 0x00007fbd0e18b9ca in vkiPanic () from /raid/lib/libeos-System.so
#2 0x00007fbd0e18bb0a in _vkiReboot () from /raid/lib/libeos-System.so
#3 0x00007fbd0e1874f7 in _vkiLogMsg () from /raid/lib/libeos-System.so
#4 0x00007fbd0e187923 in _vkiCmnErr () from /raid/lib/libeos-System.so
#5 0x00007fbd0e16cba7 in utlAssertTFL () from /raid/lib/libeos-System.so
#6 0x00007fbcf662d0b1 in utl::slist_frame, symrpc::IovBuf<4096>::Next>::slist_frame(symrpc::IovBuf<4096>*) () from /raid/lib/libeos-RAID.so
#7 0x00007fbcf662cf03 in symrpc::UtmService::sendMsg(symrpc::SvcIos*) () from /raid/lib/libeos-RAID.so
#8 0x00007fbcf66240a0 in symrpc::DispatchService::task() () from /raid/lib/libeos-RAID.so
#9 0x00007fbcf6624191 in symrpc::DispatchService::taskStart(symrpc::DispatchService*) () from /raid/lib/libeos-RAID.so
#10 0x00007fbd0e18f188 in vkiTask () from /raid/lib/libeos-System.so
#11 0x00007fbd0cbbd064 in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#12 0x00007fbd0d53962d in clone () from /lib/x86_64-linux-gnu/libc.so.6
RegisterValues:
