跳转到主内容
在E系列环境中使用Oracle ASM执行持续Linux主机DMMP故障转移
适用场景
  • E 系列
  • Oracle ASM
  • 设备映射程序多路径( DMMP )
问题描述
E系列产品可能出现以下症状:
  • 持续故障转移
  • 隐式卷传输
  • 非首选路径消息上的LUN
  • 影响性能
以下错误讯息在主机日志( /var/log/messages )中反复报告:
May 18 03:47:40 hostname kernel: sd 5:0:0:3: rdac: array example, ctlr 0, queueing MODE_SELECT command
May 18 03:47:40 hostname kernel: sd 5:0:0:3: rdac: array example, ctlr 0, MODE_SELECT returned with sense 06/94/01
May 18 03:47:40 hostname kernel: sd 5:0:0:3: rdac: array example, ctlr 0, retrying MODE_SELECT command
May 18 03:47:40 hostname kernel: sd 5:0:0:3: rdac: array example, ctlr 0, MODE_SELECT completed
May 18 03:48:00 hostname multipathd: vol1: load table [0 209715200 multipath 1 queue_if_no_path 1 rdac 2 1 round-robin 0 1 1 8:144 1 round-robin 0 1 1 8:112 1]
May 18 03:48:21 hostname multipathd: vol3: load table [0 629145600 multipath 1 queue_if_no_path 1 rdac 2 1 round-robin 0 1 1 8:80 1 round-robin 0 1 1 8:64 1]
May 18 03:48:21 hostname kernel: sd 5:0:0:1: rdac: array example, ctlr 0, queueing MODE_SELECT command
May 18 03:48:21 hostname kernel: sd 5:0:0:1: rdac: array example, ctlr 0, MODE_SELECT returned with sense 06/94/01May 18 03:48:21 hostname kernel: sd 5:0:0:1: rdac: array example, ctlr 0, retrying MODE_SELECT command
May 18 03:48:21 hostname kernel: sd 5:0:0:1: rdac: array example, ctlr 0, MODE_SELECT completed
May 18 03:48:40 hostname multipathd: vol2: load table [0 209715200 multipath 1 queue_if_no_path 1 rdac 2 1 round-robin 0 1 1 8:160 1 round-robin 0 1 1 8:176 1]
May 18 03:48:40 hostname kernel: sd 6:0:0:4: rdac: array example, ctlr 1, queueing MODE_SELECT command
May 18 03:48:40 hostname kernel: sd 6:0:0:4: rdac: array example, ctlr 1, MODE_SELECT returned with sense 06/94/01
May 18 03:48:40 hostname kernel: sd 6:0:0:4: rdac: array example, ctlr 1, retrying MODE_SELECT command
May 18 03:48:40 hostname kernel: sd 6:0:0:4: rdac: array example, ctlr 1, MODE_SELECT completed
New to NetApp?
Scan to view the article on your device
