跳转到主内容
VASA Provider:ESXi和VP之间的SSL握手失败、并显示"证书验证失败"
210
Visibility:
Votes:
0
Category:
netapp-vasa-provider
Specialty:
VIRT
Last Updated:
适用场景
  • 适用于VMware的ONTAP工具(OTV)
  • VASA Provider (VP)
  • vVol
  • VMware vSphere
问题描述
  • 无法访问创建的VVOV数据存储库、此数据存储库可能显示 为0字节
  •  vvold.log 在ESXi主机上、与VASA Provider通信时报告SSL握手错误:
2022-06-21T16:37:21.805Z warning vvold[2574793] [Originator@6876 sub=IO.Connection opID=xxxx] Failed to SSL handshake; SSL(<io_obj p:xxxxx,
h:14, <TCP 'xxx.xxx.xxx.xxx : 25608'>, <TCP '<vasa_provider_ip> : 9083'>>), e: 336134278(certificate verify failed), duration: 3msec
2022-06-21T16:37:21.805Z warning vvold[2574793] [Originator@6876 sub=HttpConnectionPool-000000 opID=xxxx] Failed to get pooled connection; <cs p:xxx, TCP:<vasa_provider_ip>:9083>, SSL(<io_obj p:xxxx, h:14, <TCP 'xxx.xxx.xxx.xxx : 25608'>, <TCP '<vasa_provider_ip> : 9083'>>), duration: 4msec, N7Vmacore3Ssl18SSLVerifyExceptionE(SSL Exception: Verification parameters:
--> PeerThumbprint: XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX:XX
-->ExpectedThumbprint:
--> ExpectedPeerName: <vasa_provider_ip>
--> The remote host certificate has these problems:
--> * unable to get local issuer certificate)
New to NetApp?
