跳转到主内容
OTV :实施 CA 签名证书后向 vCenter 注册 OTV 时出现问题
138
Visibility:
Votes:
0
Category:
virtual-storage-console-for-vmware-vsphere
Specialty:
virt
Last Updated:
适用场景
适用于 VMware vSphere 的 ONTAP 工具( OTV )
问题描述
将 VSC ( Virtual Storage Console )的自签名证书替换为 CA (证书颁发机构)签名的证书时,会出现以下问题:
  • 在 vSphere HTML5 UI 中,与 VSC/OTV 关联的发现任务会按预期显示为近期任务
  • 但是, vSphere HTML5 UI 中不会显示 OTV 菜单和图标
  • 在上通过 VMware 的受管对象浏览器( Managed Object Browser , MOB )查看已注册的 OTV 扩展 https://<vcenter>/mob/?moid=ExtensionManagercom.netapp.vsch5 时,此扩展丢失
  • 在注册期间, OTV 的 out.log 在更新 vSphere 扩展时显示以下空指针异常:
16:14:24.139 [timerFactory-1] INFO com.netapp.nvpf.container.vsphere.VSphereExtensionRegistrationManager - Updated vSphere extension definition (key: com.netapp.nvpf) with vCenter server at https://192.168.0.31:443/sdk.
16:14:24.145 [timerFactory-1] DEBUG com.netapp.common.util.ConfigProperty - UTIL-00100: Application property server.host is not defined
16:14:24.145 [timerFactory-1] DEBUG com.netapp.nvpf.container.ServerProperties - VSC returninig pureIPv4 : 192.168.0.31
16:14:24.238 [timerFactory-1] WARN com.netapp.nvpf.container.vsphere.VSphereExtensionRegistrationManager - Failed to register or update vSphere extension.
java.lang.NullPointerException: null
   at com.netapp.nvpf.container.vsphere.HTMLClientExtensionBuilder.getSSLThumbPrint(HTMLClientExtensionBuilder.java:107)
   at com.netapp.nvpf.container.vsphere.HTMLClientExtensionBuilder.build(HTMLClientExtensionBuilder.java:57)
   at com.netapp.nvpf.container.vsphere.VSphereExtensionRegistrationManager$1.execute(VSphereExtensionRegistrationManager.java:182)
   at org.apache.commons.collections.functors.ClosureTransformer.transform(ClosureTransformer.java:73)
   at com.netapp.nvpf.container.vsphere.ServiceInstanceManager.withServiceInstance(ServiceInstanceManager.java:53)
   at com.netapp.nvpf.container.vsphere.ServiceInstanceProvider.withServiceInstance(ServiceInstanceProvider.java:73)
   at com.netapp.nvpf.container.vsphere.ServiceInstanceProvider.withServiceInstance(ServiceInstanceProvider.java:90)
   at com.netapp.nvpf.container.vsphere.ServiceInstanceProvider.withAdminServiceInstance(ServiceInstanceProvider.java:219)
   at com.netapp.nvpf.container.vsphere.ServiceInstanceProvider.withAdminServiceInstance(ServiceInstanceProvider.java:197)
   at com.netapp.nvpf.container.vsphere.VSphereExtensionRegistrationManager.registerOrUpdateExtension(VSphereExtensionRegistrationManager.java:67)
   at com.netapp.nvpf.container.vsphere.VSphereExtensionRegistrationManager.tryAndWarnExtensionRegistration(VSphereExtensionRegistrationManager.java:247)
   at com.netapp.nvpf.container.vsphere.VSphereCredentialFileWatcher.onChange(VSphereCredentialFileWatcher.java:45)
   at com.netapp.nvpf.container.vsphere.VSphereCredentialFileWatcher.checkForChange(VSphereCredentialFileWatcher.java:39)
   at com.netapp.nvpf.container.vsphere.VSphereCredentialFileWatcher.run(VSphereCredentialFileWatcher.java:51)
New to NetApp?
