跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
OTV:添加存储时出错"节点管理LIF IP地址"
Visibility:
Votes:
0
Category:
virtual-storage-console-for-vmware-vsphere<a>2008968710</a>
Specialty:
virt
Last Updated:
适用场景
  • ONTAP 9.8
  • ONTAP 9.9.x
  • Virtual Storage Console ( VSC ) 9.7.x
  • 适用于 VMware vSphere 的 ONTAP 工具( OTV )
问题描述
  • VSC无法添加存储系统、并显示以下错误:
Error occured while adding Storage System. Node Mgmt LIF IP Address
  • LIF IP 地址位于状态为 local-only Failover Policy的集群管理 LIF 上。
Cluster2::> network interface show -lif cluster_mgmt -instance
            Vserver Name: cluster2
       Logical Interface Name: cluster_mgmt
           Service Policy: default-management
            Service List: management-core, management-autosupport,
                   management-ssh, management-https,
                   management-ems
         (DEPRECATED)-Role: node-mgmt
           Data Protocol: none
          Network Address: 10.216.13.186
              Netmask: 255.255.255.0
        Bits in the Netmask: 24
             Is VIP LIF: false
            Subnet Name: -
             Home Node: cluster2-01
             Home Port: e0a
            Current Node: cluster2-01
            Current Port: e0a
         Operational Status: up
          Extended Status: -
              Is Home: true
       Administrative Status: up
          Failover Policy: local-only
          Firewall Policy: mgmt
            Auto Revert: true
   Fully Qualified DNS Zone Name: none
      DNS Query Listen Enable: false
        Failover Group Name: Default
              FCP WWPN: -
           Address family: ipv4
              Comment: -
           IPspace of LIF: Default
   Is Dynamic DNS Update Enabled?: false
Probe-port for Cloud Load Balancer: -
          Broadcast Domain: Default
            Vserver Type: admin
New to NetApp?
Scan to view the article on your device
