OTV无法在ESXi主机和集群级别配置NFS数据存储库
适用场景
- 适用于 VMware vSphere 的 ONTAP 工具( OTV )
- VMware vSphere
问题描述
- OTV 无法配置NFS数据存储库:
Cannot create or mount NFS datastore because either none of your ESX host's VMkernel interfaces share a subnet with the controller or it would create anindirect data path. Try adding the network of the VMkernel interface(s) you'd like to use to mount to the default.allow.nfs.mount.networks property in the kaminoprefs.xml preferences file.
- OTV
kamino.log
节目Controller address ip_address dose NOT match VMkernel networks.
INFO [DatastoreIpHash] - DatastoreIpHash: Controller address xxx.xxx.xx.xx does NOT match VMkernel networks.
- 如果 在vCenter中手动创建和挂载NFS数据存储库而不使用OTV、则此功能可以正常工作
