存储复制适配器( SRA ): 300 秒后操作超时
适用于
- Site Recovery Manager ( SRM )
- Storage Replication Adapter (SRA)
问题
SRM 用于存储任务的默认超时设置为 300 秒。如果超过此超时值,您可能会在 SRM 日志中看到类似于以下内容的事件:
2016-05-31T23:13:07.277-04:00 [10712 error 'RemoteTaskMonitor' remoteTask=dr.storage.ReplicatedArrayPair.reverseReplication4614] Dr::Internal::RemoteTask::Fail: The remote task failed: error=
--> std::exception 'class Dr::TimeoutException' "Operation timed out after '300.005057' seconds"
2016-05-31T23:13:07.288-04:00 [11248 error 'Recovery' ctxID=727c8422 opID=311ccf49] [revRepl] Operation reverse replication failed for group [dr.replication.ProtectionGroup:protection-group-5048]: (dr.storageProvider.fault.StorageReverseReplicationFailed) {
--> dynamicType = ,
--> faultCause = (dr.fault.Timedout) {
--> dynamicType = ,
--> faultCause = (vmodl.MethodFault) null,
--> timeout = 300,
--> msg = "",
--> msg = "",
