跳转到主内容
SRA:未映射的LUN可能会影响设备发现
21
Visibility:
Votes:
0
Category:
not set
Specialty:
virt
Last Updated:
适用场景
  • Site Recovery Manager ( SRM )
  • Storage Replication Adapter ( SRA ) 4.0P1 , 7.0 , 7.1 , 7.2
问题描述
在 Site Recovery Manager ( SRM )中运行设备发现操作时,可能会出现以下错误:
'XlValidateException' error : Reviewing the discoverDevices response in the SRM logs shows that no SourceDevice is Return and that an XML parsing error
Site Recovery Manager (SRM)
is thrown immediately after the XML output is received :
2018-07-11T18:25:11.524Z verbose vmware-dr[06540] [Originator@6876 sub=SraCommand opID=150eed55] discoverDevices responded with:
--><?xml version="1.0" encoding="UTF-8"?><Response xmlns="http://www.vmware.com/srm/sra/v2" xmlns:replication="http://www.vmware.com/srm/sra30" xmlns:foo="http://www.foo.com/sra/v2">
-->        <ReplicatedDevices>
-->            <ConsistencyGroups>
-->                <ConsistencyGroup id="//svm1/CG_vol01" state="read-write">
-->                     <SourceDevices></SourceDevices>
-->                    <TargetGroup key="//svm2/CG_vol01_mirror"></TargetGroup>
-->                </ConsistencyGroup>
-->            </ConsistencyGroups>
-->            <SourceDevices>
-->                <SourceDevice id="//svm1/nfs1" state="read-write">
-->                    <Identity>
-->                        <NfsName>/nfs1</NfsName>
-->                    </Identity>
-->                    <TargetDevice key="//svm2/nfs1_dr"></TargetDevice>
-->                </SourceDevice>
-->            </SourceDevices>
-->            <StoragePorts>
-->                <StoragePort id="192.168.0.131" type="NFS"></StoragePort>
-->            </StoragePorts>
-->            <TargetDevices>
-->                <TargetDevice key="//svm1/nfs2_dr"></TargetDevice>
-->            </TargetDevices>
-->        </ReplicatedDevices>
-->        <Warnings>
-->            <Warning code="2067"></Warning>
-->        </Warnings>
-->    </Response>
2018-07-11T18:25:11.529Z error vmware-dr[06540] [Originator@6876 sub=Storage opID=150eed55] XML parsing error in 'buffer' at (6, 52): empty content is not valid for content model '(SourceDevice+)'
" 找不到匹配的设备 " 错误:
查看 SRM 日志中的 "发现 设备 " 响应,发现找不到 " 找不到匹配的设备 " 错误中所调用的设备的对等设备。  尽管阵列设备处于运行正常的 SnapMirror 关系中:
2018-07-30T15:48:26.871Z verbose vmware-dr[03852] [Originator@6876 sub=Storage] Dr::Storage::VmomiLayer::StretchedDatastoreMonitor::PeerArrayPairPropertiesChanged: Received an update for peer array pair MoRef=dr.storage.ReplicatedArrayPair:ec07e4f6-8548-48ce-a00e-58f74467c415:array-pair-2053, local array pair MoRef=[dr.storage.ReplicatedArrayPair:41961a8a-6c85-485f-88bf-68111d5509e1:array-pair-2052], deleted=false, changes=
--> (vmodl.query.PropertyCollector.Change) [
-->    (vmodl.query.PropertyCollector.Change) {
-->       name = "device",
-->       op = "assign",
-->       val = (dr.storage.StorageDevice) [
-->          (dr.storage.StorageDevice) {
-->             id = "//svm2/Unmapped_mirror/unmapped_lun",
-->             name = <unset>,
-->             stretchedStorage = false,
-->             staticSitePreference = <unset>,
-->            peerId = <unset>,
-->             peerName = <unset>,
-->             groupId = <unset>,
-->             groupName = <unset>,
-->             peerGroupId = <unset>,
-->             peerGroupName = <unset>,
-->             role = "target",
-->             targetKey = <unset>,
-->             snapshot = (dr.storage.Snapshot) null,
-->             details = <unset>,
-->             queryDetailsFault = (vmodl.MethodFault) null,
-->             replicationSettings = <unset>,
-->             queryReplicationSettingsFault = (vmodl.MethodFault) null
" 未映射 " 卷处于运行正常的 SnapMirror 关系中:
cluster2::> snapmirror show
        Progress
Source            Destination Mirror  Relationship   Total             Last
Path        Type  Path        State   Status         Progress  Healthy Updated
svm1:Unmapped
            XDP  svm2:Unmapped_mirror
                              Snapmirrored
                                      Idle           -         true    -
" 未找到 SnapMirror 关系 " 错误:
在阵列管理器中填充卷包含字段时,在设备发现期间可能会出现以下 " 未找到 SnapMirror 关系 " 错误:
New to NetApp?
