存储复制适配器: SRA 设备服务未运行且 java.io.ioException
- 172
- Visibility:
- Public
- Votes:
- 0
- Category:
- ontap-storage-replication-adapter
- Specialty:
- virt
- Last Updated:
状态信息
适用于
- Storage Replication Adapter for SRM
- 存储复制适配器 4.0
- 存储复制适配器 7.x
问题
在 Site Recovery Manger 中执行任务时,操作失败。 SRM 日志表明,当 SRM 调用 SRA 适配器(即 Command.pl )时会生成超时:
--> (dr.storage.fault.CommandFailed) { --> faultCause = (dr.fault.InternalError) { --> faultCause = (vmodl.MethodFault) null, --> reason = "500 Can't connect to <sra_appliance>:9083 (timeout) at C:Program FilesVMwareVMware vCenter Site Recovery ManagerstoragesraCMODE_ONTAPcommand.pl line 301 --> ", --> msg = "Internal error: 500 Can't connect to <sra_appliance>:9083 (timeout) at C:Program FilesVMwareVMware vCenter Site Recovery ManagerstoragesraCMODE_ONTAPcommand.pl line 301 Can't retrieve SRA logs due to error java.io.IOException: No space left on device
