无法在 SRM/SRA 中升级副本设备错误
适用于
- Data ONTAP 7-模式
- FAS/V 系列存储复制适配器
- NFS
问题
在 SRM 中执行恢复操作时报告以下错误信息:
Error - Failed to promote replica devices. Failed to promote replica device '/vol/volume_name. SRA command 'failover' failed for device '/vol/volume_name'. Unable to export the NAS device. Ensure that the correct export rules are specified in the ontap_config.txt file.
