跳转到主内容
SMBR 因缺少 PowerShell 模块而失败并显示 "Command Mounting-SdSnapshot Failed" 发生原因
132
Visibility:
Votes:
0
Category:
single-mailbox-recovery-smbr
Specialty:
legacy
Last Updated:
适用场景
  • Single Mailbox Recovery (SMBR)
  • 适用于Windows的SnapCenter插件(SCW)
  • 适用于Exchange的SnapCenter插件(SCE)
  • SnapDrive for Windows (SDW)
问题描述
  • 在恢复期间、如果选择 挂载/启动 按钮、则图形用户界面将显示:
    "Command Mount-SdSnapshot failed. Please contact technical support representative"
  • SnapshotManager.log 可能包括 以下陈述之一:
    1. A parameter cannot be found that matches parameter name 'AutopickMountPoint'.Exception stack:
    2. ERROR ao - Command execution error: FullyQualifiedErrorId: System.ArgumentExceptionException message: Input path '<LUN_Path>'  is not supported :Exception stack:
  • System.Management.Automation.CommandNotFoundException:
    The command "Open-SmConnection" is not recognized as the name of a cmdlet, a function, a script file or an executable program. Check the spelling of the command, and if the path is correct (if contained), and retry the command.
New to NetApp?
