ONTAP Select : RDB HA 配置 UUID 与集群 UUID 不匹配
适用于
- ONTAP Select
- 高可用性 (HA)
问题
无法在 ONTAP Select 集群上启用 HA 。
Cluster::*> cluster ha modify -configured true
Warning: High Availability (HA) configuration for cluster services requires that both SFO storage failover and SFO auto-giveback be enabled. These actions will
be performed if necessary.
Do you want to continue? {y|n}: y
Error: command failed: RDB dblade agent: RDB HA configuration UUID does not match cluster UUID.
