跳转到主内容
在ONTAP 集群上执行评估时、7-MTT出错
适用场景
  • ONTAP 9.10.1P3
  • 7-模式过渡工具(7-MTT) 3.5.0
问题描述
在7-MTT中对ONTAP 集群执行初始评估时出错:
Unable to connect to the controller HTTPD or SSH port. (Errno: 10061, No connection could be made because the target machine actively refused it). Check if HTTPD is enabled using 'options httpd.admin.enable on'. Check if SSH2 is enabled using 'secureadmin' command. Check if SSL is enabled using 'options ssl'. Check the credentials and user privileges.
New to NetApp?
