跳转到主内容
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
命令失败:无法在ONTAP 中为卷设置卷属性"files"
31
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
  • 索引节点计数
问题描述
尝试将索引节点编号更改为特定编号时、可能会出现以下错误消息。
示例:
cluster::> df -i
Filesystem      iused   ifree    %iused    Mounted on     Vserver
/vol/Share01/   2027    21249099 0%        /Share01       svm_01
cluster::> vol show
Vserver   Volume     Aggregate    State      Type Size       Available  Used%
svm_01    Share01      aggr1      online    RW   100GB      94.85GB    0%
cluster::> vol modify -volume Share01 -files 42502252
Error: command failed: Unable to set volume attribute "files" for volume "Share01" on Vserver "svm_01".
Reason: The value you entered(42502252) is invalid; maximum inode count cannot exceed 24903679.
Cannot support more than one inode per 4 KB of disk space.
New to NetApp?
New to NetApp?
Scan to view the article on your device
