跳转到主内容
无法修改卷效率策略、也无法提升卷
174
Visibility:
Votes:
2
Category:
not set
Specialty:
not set
Last Updated:
适用于
ONTAP 9.3 及更高版本
问题
  • 卷效率(重复数据删除)作业未在卷上运行,修改卷效率选项的任何尝试均会失败:
Cluster01::> volume efficiency modify -vserver svm1 -volume vol1 -policy auto
Error: command failed: Failed to modify efficiency configuration for volume "vol1" of Vserver "svm1": Cannot perform efficiency operations on deprioritized volume.  To be able to perform efficiency operations, run "volume efficiency promote" command first.  If there are active SIS operations then use the "volume efficiency stop -all true -vserver * -volume *" command to stop all efficiency operations on all volumes in the cluster.
  • volume efficiency promote建议运行将返回以下内容:
Cluster01::> volume efficiency promote -vserver svm1 -volume vol1
Error: command failed; Cannot promote volume "vol1" because the efficiency policy associated with the volume is not auto policy.
  • 检查卷选项会显示未配置计划或效率策略:
Cluster01::> volume efficiency show -vserver svm1 -volume vol1 -instance
      Vserver Name: svm1
      Volume Name: vol1
         State: Enabled
         Status: Idle
        Schedule: -
Efficiency Policy Name: -
New to NetApp?
