创建卷失败、并出现“ Operation is Disallowed ”(不允许操作)错误
状态信息
适用于
- ONTAP 8
- ONTAP 9
问题
尝试创建新卷失败、并出现以下任何错误:
Error: command failed: [Job 706] Job failed: Failed to create the volume on node "cluster-01". Reason: Operation is disallowed on an aggregate which is not home.
... error creating volume: API status: failed, Reason: Failed to create the volume on node \"volume-01\". Reason: Operation is disallowed on an aggregate which is not home. , Code: 13130] (will retry upon resync)" ...
