在 7MTT 中对连接或可访问性问题(集群模式 Data ONTAP )进行故障排除
适用于
- 7MTT
- Data ONTAP 8 7-模式
- 集群模式 Data ONTAP
问题
- 症状 1 :
过渡操作失败,并显示以下阻止错误:
01032: Communication problem occurred. [ Error ]
> Timeout occurred while communicating with Cluster-Mode storage system '<IP Address >'.
> CORRECTIVE-ACTION: Check your network configuration, correct the problem and re-run the operations.
- 症状 2 :
向导在提供集群详细信息时失败,并显示以下错误:
Step: Select target cluster
Enter the FQDN or management IP address of the cluster: <IP Address >
Enter the administrative user-name for the cluster <IP Address > [admin]:
Enter the password for 'admin@<IP Address >':
ERROR: Host '<IP Address >' timed out.
- 症状 3.
7- 模式过渡工具 > 过渡凭据 add -h <IP Address > -u admin
输入 "admin@ <IP Address >" 的密码:
Error (31009) : Host '<IP Address >' timed out .
