分层不适用于分层策略为 "all" 的卷和 AWS 对象存储
适用场景
- ONTAP 9
- FabricPool
- Amazon Web Services ( AWS )
问题描述
所有聚合都已附加一个对象存储并可用:
::*> storage aggregate object-store show -fields aggregate, object-store-name, object-store-availability, tiering-fullness-threshold, license-used-percent
aggregate object-store-name object-store-availability license-used-percent tiering-fullness-threshold
aggr_01 S3Bucket available - 30%
aggr_02 S3Bucket available - 30%
aggr_03 S3Bucket available - 30%
但是,所有数据都驻留在性能层中,不会将任何数据分层到容量层:
::> volume show-footprint -vserver vserver1 -volume vol1
Volume : vol1
Feature Used Used%
Volume Data Footprint 9. 36TB 11%
Footprint in Performance Tier 9. 43TB 101%
Flexible Volume Metadata 57. 4GB 0%
Deduplication 53. 0GB 0%
Delayed Frees 76. 6GB 0%
Total 9. 54TB 11%
Profiler
连接测试因 PUT 失败而失败:::*> storage aggregate object-store profiler show
Object store config name: S3Bucket
Node name: cluster-01
Status: Aborted due to PUT failure
Start time: 7/24/2020 09:19:20
Op Size Total Failed Latency(ms) Throughput
min max avg
PUT 4MB 51 51 524 7718 7384 0B
GET 4KB 0 0 0 0 0 0B
GET 8KB 0 0 0 0 0 0B
GET 32KB 0 0 0 0 0 0B
GET 256KB 0 0 0 0 0 0B
5 entries were displayed.
