跳转到主内容
由于LIF迁移失败、控制器升级后无法执行接管
27
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2009年296614</a>
Last Updated:
适用场景
  • 4 节点集群
  • 在一个HA对中升级控制器
问题描述
由于LIF迁移问题描述 、接管一个节点失败
Cluster::*> takeover -ofnode node-01
(storage failover takeover)
Warning: A takeover will be initiated. Once the partner node reboots, a giveback will be automatically initiated. Do you want to continue? {y|n}: y
Error: command failed: Could not migrate LIFs away from node "node-01": Reason Failed to migrate one or more LIFs away from node "node-01". Use the "network interface show -curr-node node-01" command to identify LIFs that could not be migrated off that node. Use the "network interface migrate" command to manually migrate the LIFs off the node. Run "storage failover show" to confirm node "node-01" is operational.  If node is operational, reissue the takeover command with "-skip-lif-migration-before-takeover" to skip the migration and proceed with takeover.
New to NetApp?
