跳转到主内容
系统配置备份失败 mgmtgwd.configbr.deleteFailed
150
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
适用场景
  • ONTAP 9
  • 系统配置备份
问题描述
指示备份归档创建失败的日志消息:
cluster_backup_job::queue_local_backup_jobs - Failed to queue local job for %s Error: %s
cluster_backup_job::check_for_node_backups - Node: %s Backup Errored.
cluster_backup_job::check_for_node_backups - Failed to get job info for node: %s
cluster_backup_job::queue_local_backup_jobs - The node %s is not included in cluster backup
config_backup_create_handler::create_local_tarball - Failed to get the value of thebootarg.init.cfimagebase variable
config_backup_create_handler::create_snapshot - Failed to get rdb version
fill_node_backup_list - Could not find the directory %s to be backed-up
generate_cluster_conf_manifest - Could not determine the cluster uuid
generate_cluster_conf_manifest - Could not determine the software version
generate_node_conf_manifest - Could not determine the software version
generate_node_conf_manifest - Could not determine the hardware model
config_backup_restore_ops::create_dir - Failed to create the backup dir because of: %d
config_backup_restore_ops::create_dir - Found a non-directory in place of the backup dir
config_backup_restore_ops::create_dir - Found invalid permissions on backup dir
config_backup_create_handler::create_snapshot - root snapshot delete zapi failed:retval: %s
config_backup_restore_ops::clean_snapshots - failed to delete snapshot %s
config_backup_create_handler - failed to delete the temp dir %s
EMS 消息
EMS 标识符 mgmtgwd.configbr.deleteFailed
系统日志消息 无法删除节点 %s 上的 %s 配置备份 %s 。错误:“%s”。
严重性 错误
问题描述 如果无法删除旧配置备份,则会显示此消息。
更正操作 确保节点可访问且运行状况良好。如有必要,请手动删除备份。
New to NetApp?
