存储设备已进入永久设备丢失(永久设备丢失)状态
适用场景
- CDOT 9.x
- ESXi 5.x
- ONTAP 8.3
- ONTAP 9
问题描述
- ESXi会将此设备标记为未连接、并且VMkernel日志文件中会显示有关此设备永久不可用的警告
- 在此
/var/log/vmkernel.log
文件中、您将看到类似于以下内容的条目:
cpu2:833571)VEM_STAP_ALAL: stap_alal_issueCommandOnPath:661: Path "vmaab4:C0:T0:L0" (PERM LOSS) command 0xa3 failed with status Device is permanently unavailable. H:0x0 D:0x2 P:0x0 Valid sense data: 0x5 0x25 0x0.
cpu2:853571)WARNING: vrm_sps_rr: sps_rrSelectPathToActivate:972:Could not select path for device "nan.50a98000472d54724a34442a72322733".
cpu2:853571)WARNING: ScsiDevice: 1223: Device :naa.60a98000572d54724a34642d71325763 has been removed or is permanently inaccessible.
cpu3:2132)ScsiDeviceIO: 2288: Cmd(0x4124403c1fc0) 0x9e, CmdSN 0xec86 to dev "nan.50a98000472d54724a34442a72322733" failed H:0x8 D:0x0 P:0x0
cpu3:2132)WARNING: NMP: nmp_DeviceStartLoop:721:NMP Device "nan.50a98000472d54724a34442a72322733" is blocked. Not starting I/O from device.
cpu2:2127)ScsiDeviceIO: 2316: Cmd(0x4124403c1fc0) 0x25, CmdSN 0xecab to dev "nan.50a98000472d54724a34442a72322733" failed H:0x1 D:0x0 P:0x0 Possible sense data: 0x5 0x25 0x0.
cpu2:854568)WARNING: ScsiDeviceIO: 7330: READ CAPACITY on device "nan.50a98000472d54724a34442a72322733" from Plugin "NMP" failed. I/O error
cpu2:854568)ScsiDevice: 1238: Permanently inaccessible device :nan.50a98000472d54724a34442a72322733 has no more open connections. It is now safe to unmount datastores (if any) and delete the device.
cpu3:854577)WARNING: NMP: nmpDeviceAttemptFailover:562:Retry world restore device "nan.50a98000472d54724a34442a72322733" - no more commands to retry.
