单节点 Azure CVO 重新启动而不发生 Azure 维护事件
- 1
- Visibility:
- Public
- Votes:
- 0
- Category:
- cloud-volumes-ontap-cvo
- Specialty:
- cloud<a>重新启动</a><a>Azure CVO</a><a>2008787341</a><a>单节点</a><a>无Azure维护事件</a><a>Hyper-V关闭</a>
- Last Updated:
适用场景
- Azure CVOSingle Node
- 无冻结或 NIC 断开等维护事件
- 重新启动
- Hyper-V 关闭子虚拟机
问题描述
- 一小时内无法访问单节点 Azure CVO 并重新启动
EMS.log
Fri May 28 02:02:00 -0400 [Cluster-01: mgwd: clus.reboot.rebootDetected:notice]: Cluster reboot was detected at 01/01/2021 00:00:00. Sequence number for the cluster reboot was 5. Estimated beginning time of the cluster reboot was 01/01/2021
- CVO 已停止, Azure 活动日志显示它已被 Cloud Manager 停止。
