SP HW Assist - ONTAP 9 で UDP ソケットのバインドに失敗しました
- 55
- Visibility:
- Public
- Votes:
- 0
- Category:
- ontap-9
- Specialty:
- hw<a>2008553361</a><a>HW アシスト</a>
- Last Updated:
のとう
のとう
環境
- ONTAP 9
- SP
- BMC
- AFFシステム
- FASシステム
問題
内部スイッチのハードウェアアシストの更新を含むSPの更新の実行後、パートナーへの接続に失敗する
- EMS
Cluster-1b ERROR cf.hwassist.missedKeepAlive: HW-assisted takeover missing keep-alive messages from HA partner (Cluster-1a).
- Command Line
Cluster::> storage failover hwassist show Node ----------------- Cluster-1a Partner: Cluster-1b Hwassist Enabled: true Hwassist IP: 10.4.17.224 Hwassist Port: 4444 Monitor Status: inactive Inactive Reason: Fail to bind UDP socket. Corrective Action: Run 'storage failover modify -hwassist-partner-ip <Cluster-1a's node management IP> -node Cluster-1b' and/or run 'storage failover modify -hwassist-partner-port <Cluster-1a's UDP port> -node Cluster-1b' Keep-Alive Status: - Cluster-1b Partner: Cluster-1a Hwassist Enabled: true Hwassist IP: 10.4.17.225 Hwassist Port: 4444 Monitor Status: inactive Inactive Reason: Fail to bind UDP socket. Corrective Action: Run 'storage failover modify -hwassist-partner-ip <Cluster-1b's node management IP> -node Cluster-1a' and/or run 'storage failover modify -hwassist-partner-port <Cluster-1b's UDP port> -node Cluster-1a' Keep-Alive Status: - 2 entries were displayed.
のとう
のとう
