发生意外断电后需要进行根卷恢复
状态信息
适用场景
- ONTAP 9
- 因断电而关闭
问题描述
ONTAP启动意外断电、并显示以下消息:
The contents of the root volume may have changed and the local management configuration may be inconsistent and/or the local management databases may be out of sync with the replicated databases. This node is not fully operational.
Contact support personnel for the root volume recovery procedures.
[cluster:callhome.root.vol.recovery.reqd:EMERGENCY]: Call home for ROOT VOLUME NOT WORKING PROPERLY: RECOVERY REQUIRED.
Internal error: Cannot open corrupt replicated database. Automatic recovery attempt has failed or is disabled. Check the event logs for details. This node is not fully operational. Contact support personnel for the root volume recovery procedures.
