跳转到主内容
当 E0M 管理接口与生产流量位于同一子网上时,以太网网络的性能问题
17
Visibility:
Votes:
0
Category:
data-ontap-7
Specialty:
core
Last Updated:
状态信息
适用于
Data ONTAP 7 及更早版本
问题
如果
在重新启动 / 维护降级后、通过以太网网络影响系统网络性能、请检查 Active IQ 。
执行以下备份和传输时,存储系统上报告备份和传输缓慢问题:
  • NDMP 备份
  • SnapMirror 传输
  • SnapVault 传输
消息和 EMS 日志将以下列消息发出警告(相应地为 IPv4 或 / 和 IPv6 ):
[netapp: netmon_main: net.if.mgmt.sameSubnet:warning]: ifconfig: IP address 'x.x.x.x' configured on dedicated management port 'e0M' is on the same subnet as IP address 'x.x.x.x' configured on data port Prod1. Management IP addresses must be on dedicated management subnets.
[net.if.mgmt.defaultGateway:warning] route: Static or default route with gateway 'x.x.x.x' is targeted to dedicated management interface 'e0M'. Data traffic using this route might be throttled due to low bandwidth, or dropped if a protocol filter is configured.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
